First off, are you talking wet air dry / two-pack paint, or powder paint ?
Wet can be as little as a quick flat down, mask off & away you go. Bearings can stay in, & results will reflect the time spent.
Powder will require bearings out & fully chemically stripped. The grease in the bearings will probably run out & screw up the paint. (It’s baked at 180c). Blasting is generally just to get a nice key for powder.
It goes on by electrostatically charging the frame to attract the powder. Hence the frame needs to be bare metal. You can powder over paint, but it’s hit & miss. Mostly miss & looks truly awful.
You need to check if the bearing seats are powdered at the moment, if they are don’t worry. Most manufacturers won’t go to the hassle of masking, they will just size the housing so that after powder it will take a bearing. Powder is typically 70-100 microns thick.
If the seats are bare metal (or it’s an anodised/raw frame), then the painters will have special high temp tape that can be baked. Other method is a bung of some sort, or a rolled up peice of card.
Find a good firm, who know their stuff. Most do.
If the bearing seats are painted, & the new bearings a snug fit, wrap a peice of 500 grade emery around a pencil & swirl it around to take a bit of paint off. For gods sake don’t use a Dremmel.
