Viewing 3 posts - 1 through 3 (of 3 total)
  • Time MX pedal spring replacement
  • simons_nicolai-uk
    Smacked one of my pedals on a rock last week and now can’t clip in on one side.
    Does anyone know if the springs on these are replaceable? Is there a service guide anywhere? I have a vague memory that you need to knock out the remaining pins with a pin hammer on older time pedals but I’ve never actually done it.
    Also, any sources for the springs or are they the same as all the other round springs (so I can salvage some from a set of Aliums)
    andylakes
    Hi easy to do and I’ve replaced/swapped lots around as they have worn.
    Try here http://forums.mtbr.com/drivetrain-shifters-derailleurs-cranks/time-atac-spring-replacement-help-needed-942412.html
    Cheers.
    simons_nicolai-uk
    Hmm. That linked post talks about a threaded inner to the spring pins but the pins on the MX4’s is solid so the method they talk about isn’t going to work.
    Anyone else?
The topic ‘Time MX pedal spring replacement’ is closed to new replies.
