Thanks for the tips
I am on a welding forum also seeking advice. A lot of the folks on there seem to be welders who make what could only be described as fabrications way out of the size I am looking at ,Think oil rig pipework and the like, though there are some that have built a few bikes.Most of the courses are for coded welding or just general fabrication.
Whilst they are helpful a lot of the advice has been to try and get some tuition from someone doing something similar . I was hoping there would be somewhere local as most of the courses as mentioned above by CK are for brazing frames.
There is information on the web but even then most of the sites ar American and seem to be roll cage or experimental aircraft, again it’s plain gauge tube and still quite a bit thicker than bicycle tubes.
Ben I have tried this and well basically whilst im sure we all have to start somewhere it wasn’t great!!!
Daveport the one I got was this
http://www.r-techwelding.co.uk/welding_equipment/Tig_Welder/TIG_Welder_Digital_Series_210A_ACDC
It will also weld aluminium which is another area I would like to try
