also just to be clear, you have taken the cable off the front mech?
Sometimes sti’s can over shift and lock, although normally they go the other way
Nope, haven’t touched the cable. Not quite sure what you mean, could you clarify please? The shifter isn’t jammed, the lever (and the front mech) moves the full way across only the ratchet doesn’t engage so they just go right back again after the lever is released!
you know really you wnat 105 or above to get the nice under tape cables..
yes! Although one guy I spoke to at a LBS said this could be a bad thing as too tightly wrapped bar tape could impede the shifting… but I agree, looks much neater!
