Viewing 20 posts - 1 through 20 (of 20 total)
  • Through the frame routing… Grrrrr, how in the name of all that's Holy do you ?
  • weeksy
    Went to route my Dropper through the frame yesterday.. it has an exit and start hole pre-done. But doesn’t seem to be sleeved.
    No matter how many time I tried it, bending one way, waggling the other I couldn’t get anything at the other end… Even trying from the other end…. still no good….
    Whats the secret ?
    rOcKeTdOg
    Cotton & a vacuum cleaner
    Stoner
    no idea what the secret is, but ticking theread as Im sure I will need to know one day soon.
    EDIT: How about feeding cotton into the first hole and putting the hoover nozzle against the other end 😉
    Beaten by the Dog! Damn.
    Thrustyjust
    Thin garden wire 😀
    weeksy
    WTF…. really ? it actually sounds like a not completely daft idea… but I’d never ever have thought of that !
    rOcKeTdOg
    Invoice will be in the post shortly
    br
    Shine a light in, can you see it?
    aP
    On my Air9 Carbon I just rammed the cable out through really hard in order to break off all the sticky out bits of carbon inside the chainstay. Worked fine for me, but took about 4 hours to route the rear derailleur cable. Hope it stays good for a long time as I have to take the BB and EBB out to replace the cable. Stupid bike.
    Sodajim
    Park have a new kit for internal routing that looks pretty natty if it actually works !
    [video]https://www.youtube.com/watch?v=bS_lrnnCiAw&feature=player_embedded[/video]
    bigmick25
    I found dental floss and the hoover worked even better than cotton.
    hatter
    I’ve used on of those Park kits, bloody ace, turns it into 2 minute job.
    curiousyellow
    Magnet doesn’t mess with the bike’s paint job or finish when you scrape it along?
    nixie
    Looks cool. Not for steel frames presumably.
    Speshpaul
    “Hope it stays good for a long time as I have to take the BB and EBB out to replace the cable. Stupid bike. “
    Replacing is easy.
    take old inner out
    thread in new inner
    take old outer off
    thread on new outer.
    mjsmke
    rOcKeTdOg – you deserve a life time supply of cookies for that idea.
    hatter
    It’s smooth with rounded corners so it certainly shouldn’t, it’s almost as if somebody thought about the design *Shock horror*
    I can see it not working with steel, but in fairness not many steel frames use internal routing.
    Rorschach
    Tried the Park dohicky.Any frame where the hole were big enough for the connectors to go through it was just quicker to do it with wire.
    It did take me 6 hours to cable a Cannondale slice RS once
    tpbiker
    My new bike arrives this week and I plan to remove the front mech and go 1x.
    Am I right in thinking that if there is a cable already in there then its a relatively easy job to replace? An if thats the case, am I best leaving the existing cable in there incase I ever plan going back to a double (obviously I’d be triming it down so it only just pretrudes at both ends
    jkomo
    Put a loop through to catch the wire, as it passes pull loop, voila.
    Hoover sounds better, although as it’s STW only a Miele will work.
    globalti
    No, pull it out and plug the holes. It’s not that difficult to thread a cable.
    I bought a metre of 3.5mm CUNIFER (Copper/nickel/iron) pipe as used in Citroen hydraulic systems; that threads through OK. Also 6mm copper brake pipe works but it’s a bit thick.
    Usually you can just push the cable down then fish the end out with an old spoke.
The topic ‘Through the frame routing… Grrrrr, how in the name of all that's Holy do you ?’ is closed to new replies.
