I’m currently running the original P2 threaded fork on this but would like to replace it with a threadless one. I think the original fork might be JIS rather than 1″ but I’m not entirely sure. Ideally it would have lowrider mounts too.
Some of the older lower range Konas had 1″ forks while their more expensive brothers converted to 1.125″
I have no idea why you would want to swap one of the best rigid forks ever made for something that won’t be as good, and won’t match and look weird. Stick with threaded, there’s nothing wrong with it.
My old Cindercone is 1″ – and it has the original Kona threaded headset which can be adjusted with just an Allen key. If you can find one of those then they’re a brilliant solution.
The JIS thing is about the crown race seat diameter – they’re all 1″ headsets (the steerers are all 1″).
depends on crown to axle heights – probably fairly short on these. If you can measure or find out what it is – these could be viable http://www.carboncycles.cc/?s=0&t=2&c=82&.
I’m sure that retrobike would be able to tell you the height.
Does it still have the original Impact headset on it?
It has the original headset but it’s looking pretty sorry for itself. I’m running it with a quill to threadless adaptor which just feels like a bodge.
That said, this set up has done over 2 months worth of loaded touring and some fairly gnarly off road too so perhaps I should just leave as is.
The frame is a 1990 model which I’ve had from new. It sat in the loft for a while before I built it up as a tourer for a trip to Canada in 2010 and it has proved to be excellent in that role. The only original bits are the forks, headset and seatpost I even earned my living (barely) on that bike as a courier in the mid 90’s so it owes me nothing!.
The Impact headset is one of the best headsets ever made IMHO. My 94 Kilauea has its original headset in, now 21 years old and reinstalled after I completely restored the bike….
I’ve been on Retrobike a few years and the 1″ threadless fork issue is common, they are so rare…..
Anyway, if you have a problem with the headset loosening or you want a new headset and a more practical way of adjusting/tightening it try one of these:
Dave Yates will convert the existing fork to threadless for £80. This now seems like a lot of hassle when the existing set up is working but it’s certainly an option.
Posted 8 years ago
Viewing 28 posts - 1 through 28 (of 28 total)
The topic ‘Threadless JIS / 1" fork for old Kona Lavadome’ is closed to new replies.
