Hate it.
Awful car. Non stop niggling problems. Water leaks, rear washer stops working, interior falls to pieces. Servicing massively over priced compared to other cars, cambelts cost a fortune, suspension bushes go way too quickly. Its not easy to work on, replacing the cambelt for instance requires the front of the car to be removed to get at it. Economy isn't that great 45 ish in normal driving, though if i rigidly stick to 55mph for an hour it'll return 60mpg. Handling is awful. naff all ground clearance. overpriced 2nd hand due to VW badge engineering.
water leak from where?
rear washer is a known issue, was later changed to a metal bracket version 04/05 rollover.
my local indi is a great guy changed me £120 for a full service, showed me all changed parts and installed genuine VW PD oil to boot.
hmm cambelts are a sore point i suppose later cars like the one he is looking at require less changes, my 03 one needs a cam belt ever 80k hardly regular. cost at an indi.. £200.
only cheap replacement bushes go quick, if they do it's a £15 a bush job and none takes more than two hours to swap in pressing in and out. Genuine VW bushes on mine and my GF's she's covered over 100k before hers were replaced. i swapped my rears at.. 60k ish and one was going the other was fine. Also lowered golfs are more prone to destroying bushes.
mine for the highest power TDI pulls regular over 51 my old focus (55 plate 136bhp tdci) couldn't get over 43 mpg on the same run!
handling is a mood point, fit a rear anti roll bar and i promise all your handling issues will be gone. the golf was front heavy and needs a rear ARB to get it handling flatter.
not noticed any ground clearance issues, odd was considering dropping mine 20mm for a lower stand / COB.
wouldn't say they are that much overpriced personally BWM's are overpriced, vw's are high priced.
