Just put some F120s on my aluminium Rush that previously had a Lefty on it.
A standard 1.5″ headset will fit a Cannondale headtube. (Don’t know about integrated/ semi integrated ones.) I bought some tapered steerer F120s so got a 1.5 to taper steerer headset like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=48293
You’ll need a new stem (lefty steerers are slightly bigger than 1.5″), and at risk of stating the obvious, a new front wheel as well.
Worth mentioning that the clearance on the downtube for a normal fork crown is a bit tight as the “drop” from downtube to base of headtube isn’t as much as it is on may frames, so I’d suggest you went for a headset with as tall a lower race as you can. The NC17 I have is OK by a few mm – wouldn’t want to have much less clearance in there.
Hope that helps.
