Viewing 9 posts - 1 through 9 (of 9 total)
  • Those of you with a Hope headset – Look now!
  • MulletusMaximus
    Nothing exciting, just need a favour before I press the buy button on a standard 1 1/8 threadless headset.
    I want to be sure my steerer tube on my fork is long enough before I order, so can you lovely people take a couple of measurements for me?
    What I’m after is the overall height of your fitted headset, bottom to top of cups, also the length of your head tube.
    Thank you muchly. 😀
    hexhamstu
    Google?
    http://forums.mtbr.com/beginners-corner/hope-headset-365551.html
    Suggests the stack height is 28mm for the new style ones. So your steerer length would be heat tube length+stack height + spacers + enough for your stem.
    footflaps
    They’re a great buy, have one, it’s 12 years old, on it’s second frame and never needed any service – grease still as new.
    hexhamstu
    http://www.hopetech.com/webtop/modules/_repository/documents/HOPEHEADSETS2011Web.pdf
    They give a lot of dimensions, but not stack height for some reason.
    mikewsmith
    Call hope or go to a shop and check (then buy it there)
    hexhamstu
    http://www.westbrookcycles.co.uk/components-hardware-c8/headsets-c81/hope-1-18-headset-p2506
    Upper stack height: 17mm
    Lower stack height: 14.1mm
    Total stack height: 31.1mm
    Now what do I win?!
    MulletusMaximus
    In true STW fashion I didn’t think of google or their web site. Apparently the internet’s quite useful for things like this. 😳
    Thank you peeps. 😀
    I plan to buy one from LBS, but they don’t have any stock. Just wanted to be sure before I order one.
    IA
    Surely then the course of action is to go ask them, they find out for you and order? After all, the point of the LBS is to get service!
    honourablegeorge
    From CRC
    Head size: 1 1/8″
    Weight: 90g
The topic ‘Those of you with a Hope headset – Look now!’ is closed to new replies.
