Viewing 7 posts - 1 through 7 (of 7 total)
  • Those Cree / Ultrafire 'maglight' style torches on eBay… any use?
  • no_eyed_deer
    Looking for something helmet mounted to compliment my cheap-as-chips Magicshine ‘900’ lumen handlebar mounted thingy…
    The above ‘200’ lumen eBay torches seem like they might be alright – when used with a few bits of velcro etc. to hold in place.
    What are people’s experiences?
    AlexSimon
    I’ve got 2 – the lightweight one:
    http://www.dealextreme.com/details.dx/sku.15335
    and a slightly heavier one:
    http://www.dealextreme.com/details.dx/sku.33550
    I’ve settled on using the heavier one. The increased power and flood makes a lot of difference.
    I bought a helmet mount at the same time, but ended up just using the velcro straps from it, as they held the torch closer to the helmet, reducing the weighty feel.
    I think it’s absolutely perfect. One battery is always enough if you turn it off for the less technical bits.
    Some links to the other bits and bobs:
    http://www.dealextreme.com/details.dx/sku.6105
    http://www.dealextreme.com/details.dx/sku.12000
    http://www.dealextreme.com/details.dx/sku.20392
    (there are a few other batteries, but these have been great for me).
    no_eyed_deer
    Sounds great! but… how long does this sort of stuff take to turn up from DX these days?
    (Due to general impatience and a lack of planning, I always seem to need this stuff asap!)
    AlexSimon
    If I make a substantial order (a couple of torches and the charging gear), then it takes < 2 weeks. But a single cheap item can take 4+ weeks.
    If in a rush, you can probably find the same items on ebay from uk sellers for a bit more cash.
    TheFopster
    I’m also using the “heavier one” from post above helmet mounted. Does a superb job in conjunction with a P7 on the bars (same emitter as your Magicshine but in torch format) and plenty enough runtime for an after-work ride. Not much use if you’re doing a 24hr event, but then you knew that already. Highly recommended.
    tomaso
    Get a torch with an XM-L emitter in it. Great value and performance but as with anything cheaper the build quality won’t compare to Exposure, Hope etc
The topic ‘Those Cree / Ultrafire 'maglight' style torches on eBay… any use?’ is closed to new replies.
