- This topic has 105 replies, 44 voices, and was last updated 6 years ago by wilburt.
This wider tyres being quicker
roneFull Member
I’ve seen a few articles suggesting wider tyres are quicker or have lower rolling resistance.
I came across this website
rolling resistance site for tyres
The tyre with the lowest rolling resistance is a 2.35
Can anyone help me understand? This is something discussed on GCN to for road bikes.
Yet it goes against everything I know.
Surely this can be sorted empirically?
jam-boFull Member2.8 tyres running at 15psi were unnaturally fast.
They also punctured remarkably easily so swings and roundabouts.
roneFull MemberWhy though. All I can see is a big sloppy tyre grabbing the floor?
(I’m about to suit up with 2.8s on a new + bike)
steezysixFree MemberIt depends. Supple tyres conform to the ground better so there is less vibration and the bike “flows” over the ground faster. Same as having suspension vs. rigid on rough terrain. If the tyre is stiff or really high pressure you don’t get the advantage. Read Jan Heines blog, he explains it way better than me!
butcherFull MemberThink it depends on road surface too. A bigger tyre will roll smoother on a rough surface, is my understanding. A bigger tyre is also heavier and potentially less aerodynamic, so there’s more to consider than the rolling resistance itself.
molgripsFree MemberYes, it depends. Having ridden a stony rough trail downhill on 2.35s at 35psi with someone on 3.0s at 15psi, he was rolling straight past me as I was pedalling, the difference was astonishing.
Probably slower on smooth surfaces though.
roneFull MemberOkay I’m with this – but the GCN was referring to road cycling.
Something to do with contact patch shape?
dovebikerFull MemberThere are two main factors – the friction between the tyre and the ground, in particular the contact patch and the energy losses created by the tyre carcass deflecting. Wider tyres have a wider, shorter contact area which is smaller than a skinny tyre i.e. less friction. A wider tyre also doesn’t distort as much as a skinny tyre for the same pressure, so the energy losses are less. Off road, there are also losses due to the tyre distorting the soft surface – a wide tyre often doesn’t leave as big an imprint. Wider tyres are heavier, so lose during acceleration, but once up to speed its in the favour of the wider tyre. Wide tyres can also be run safely at lower pressures, so offroad give you more grip on rocks and roots which really helps on climbs. Aerodynamics has negligible impact on the road – makers starting to look at 28mm tyres for road racing
cynic-alFree MemberThe part of the tyre having to deform to the flat road surface is less ceived on a wider tyre so deforms less, which uses less energy
jamj1974Full MemberMass spread over a larger tyre area equalling less kg per square mm? Would that not mean less friction?
Probably wrong! 🙂
thecaptainFree MemberThe point that many many miss is that the wider tyres only have lower RR if they are at the same pressure. In reality most people ride wider tyres at lower pressure so are used to thinking of them as slow. Plus, fatter tyres have more aero resistance as well.
SaxonRiderFull MemberYou referring to me, molgrips? If so, I remember that myself, and was as astonished as you.
epicycloFull Memberrone – Member
…The tyre with the lowest rolling resistance is a 2.35Can anyone help me understand? This is something discussed on GCN to for road bikes.
It’s true. I’ve been preaching this for over 50 years.The reason it never caught on earlier is because racing doesn’t improve the breed, but fashion follows racing, and therefore wheels got thinner and thinner as roads tended towards smoother.
The end result is that road bikes were not able to fit wide tyres. Also wide tyres tended to be more for industrial uses – eg trade bicycles had 26″ tyres with 2″ section, but they were coarse with thick sidewalls, the very opposite of supple.
For several years I’ve been running converted 29ers as road bikes using Big Apple 2.35″ tyres. Freewheeling downhill beside other road bikes I have to trail my brakes to keep level.
In cycling magazines of the 1920s there would occasionally be an old hand bemoaning the lack of 2″ tyres since WW1.
The tyre manufacturers are starting to recognise this and produce suitable tyres so it’s easy enough to try if you have a 29er handy.
All you need is a supple tyre and a lower pressure than you’d think.
Comfort is much improved too.
However if you’re an actual racer I suspect 2.35″ may be a handicap at speeds where aerodynamics are critical.
benpinnickFull MemberYou’re comparing apples and oranges. Yes the rolling resistance is lowest for a 2.35, but thats also a tyre with no tread. If you look at the numbers you’ll see that construction of the tyre has a much bigger effect than size. Unfortunately while I like the site, its also limited to its sample set, so not so useful as to draw a conclusion about how size etc. effects rolling resistance (at least off road – I must confess Ive never checked out the data for the dark side). I actually offered to send the guy that runs the site a free box full of tyres to test in various sizes and compounds to get a more useful data set, but he never got back to me 🙁
13thfloormonkFull MemberTo a point I believe it, certainly never noticed any difference moving from 23 to 25 to 28, other than more comfort/confidence on descents.
However, DEFINITELY noticed the difference going from a 40 to a 32 on my commuter, even having fitted mudguards at the same time as the 32s it still feels faster. So I reckon the effect tops out somewhere.
IvanDobskiFree MemberFeeling faster isn’t necessarily the same as actually being faster though.
RustySpannerFull Membersingletrackmind – Member
Hysteresis innit???????It’s not THAT funny.
Rubber_BuccaneerFull Membersingletrackmind – Member
Hysteresis innit???????Laugh! I nearly bought one
hols2Free MemberAs I understand it, it will depend on the surface. A perfectly smooth, perfectly hard road surface would give lowest rolling resistance with a very narrow, hard tyre at very high pressure.
In the real world, the rougher the surface, the lower the ideal pressure, and the wider the ideal tyre. At the same pressure, a wide tyre and a narrow tyre will have the same contact areas, so a wider tyre will have less sidewall deflection at the same pressure.
On a soft surface, you need a tyre pressure low enough that the road surface doesn’t deform, so a wide tyre at low pressure will roll much faster.
On road, aerodynamic drag is much more important than rolling resistance, so narrow rims and tyres are faster.
teaselFree MemberOn the subject and a bit more, these are worth a read…
https://janheine.wordpress.com/2014/01/01/tires-how-wide-is-too-wide/
https://janheine.wordpress.com/2014/01/05/wide-and-fast-tires/
https://janheine.wordpress.com/2015/02/17/tire-pressure-data-and-details/
https://janheine.wordpress.com/2010/10/18/science-and-bicycles-1-tires-and-pressure/
BearBackFree Memberhigher pressures result in more vertical change in direction.. having your bike and body going up and down over rocks and roots results in a change (decrease) in your forward speed. More control to boot.
Softer tyres deform to trail imperfections and require less vertical bike deflection.
According to a pinkbike article on the topic which I cant find.
For me, 2.4″ tires at 20psi and a dad bod result in much quicker trail/race times than my old 2.0″ @40+psi back when I was fitter, lighter and riding much more.
I understand that wider road tyres are also gaining traction for their aero improvementswilburtFree MemberThe trend for wide road bike tyres is BS to sell you something new..
If wider tyres offered less rolling resistance on smooth roads I doubt the car manufacturers would be fitting super narrow high pressure tyres to cars when they game the pollution tests.
If you want to believe overwise carry on, by the way your helmet will aso explode after two years and any bike without discs is a danger to humanity.
roneFull MemberThe trend for wide road bike tyres is BS to sell you something new.
But if you’ve got to replace tyres anyway then you’d be buying something irrespective?
kerleyFree MemberThe trend for wide road bike tyres is BS to sell you something new..
A wider tyre is more comfortable, has more grip and is marginally faster and is marginally less likely to puncture. Why wouldn’t you use one?
If you think you can compare a car and it’s tyres to a bike and it’s tyres you may want to do a bit of research….
hols2Free MemberI doubt the car manufacturers would be fitting super narrow high pressure tyres to cars when they game the pollution tests
Passenger car tyres are generally inflated to 30 to 35 PSI. Skinny bike tyres are often twice that, despite carrying less than 10% of the weight. Even narrow, low rolling resistance car tyres run much lower tyre pressures than most road bikes. Also, a narrower wheel and tyre will lower a car’s aerodynamic drag enough to improve fuel consumption at highway speeds.
jamesoFull MemberI’ve seen a few articles suggesting wider tyres are quicker or have lower rolling resistance.
That test uses a flawed method though. What it’s checking for is the lowest amount of resistance to sidewall and tread flex. That will be related to actual road/trail rolling resistance in part but to be fully representative you wouldn’t use a smooth drum. Rolling resistance in the real world is related to a tyre’s ability to do what many above have described, provide the micro-suspension that stops your bike and body weight being bounced over bumps and keeps you moving forward efficiently.
Once you factor in pressures needed to prevent pinch flats, a larger tyre with less pressure and a flexible casing does that very well.Okay I’m with this – but the GCN was referring to road cycling.
Roads aren’t generally that smooth, road bikes are light and easily deflected and the speeds are high so those vibrations and small impacts are happening with a fair bit of force. Any gain in ability to manage the road surface via the tyre deformation will mean a gain in efficiency. The difference is more easily noticed off-road but the gain is there for roadies too.
pleaderwilliamsFree MemberThis is worth a listen:
CyclingTips Podcast, Episode 9: Rethinking road bike tire sizes and pressures
roneFull MemberHmm doesn’t see very clear as usual.
Maybe letting my own bike roll down a hill with different tyres on may shed some light as I pass the speed indicator at the bottom.
As for the rolling resistance test site no being very accurate, do we have an alternative? Not that I’ve seen.
crosshairFree MemberI tried a test off the back of that podcast with some 28mm Gatorskins at 200w. 120,100 and 80 psi. All three were 16.7mph. The difference in comfort was night and day though.
wilburtFree MemberNon of the reasons given explain why car manufacturers with all their resources choose narrow tyres over wide tyres to significantly reduce rolling resistance.
epicycloFull Memberhols2 – Member
As I understand it, it will depend on the surface. A perfectly smooth, perfectly hard road surface would give lowest rolling resistance with a very narrow, hard tyre at very high pressure…That’s the nub of it. The ideal is a steel wheel on a steel surface, ie rails. They have the lowest rolling resistance. SImilarly a very hard narrow tyre on smooth concrete is pretty good.
However most of us live in a real world of roads with exposed aggregate, lumpy surfaces, slightly raised manhole covers, potholes, etc etc.
I wonder how many of the naysayers have actually ridden a bike with proper wide tyres.
BTW 28mm isn’t wide. 🙂
hols2Free MemberNon of the reasons given explain why car manufacturers with all their resources choose narrow tyres over wide tyres to significantly reduce rolling resistance.
A fairly narrow car tyre is 175mm wide. A wide car tyre is twice that. They have a flat contact patch because the wheel stays close to vertical all of the time, so the contact patch is wide, hence they run fairly low pressures. A narrow bike tyre is less than 25mm wide. A wide bike for on-road is still less than 50mm wide. They have a round profile because the bike leans over massively when cornering, hence they run much higher pressures than cars. The considerations in a car tyre and bike tyre are completely different.
ctkFree MemberToo many variables in MTB imo.
With road I have the suspicion that its the ‘tallness’ of the tyre that makes the difference. ie a 28mm tyre is 5mm wider but also 5mm (ish) taller. So epicyclo when riding downhill your bigger tyres are faster because the circumference of the wheel is bigger not because of the width of tyre.
I was very disappointed when my Vittoria Corsa 25c tyres measured 23mm and with a ‘tallness’ to match the 23c Contis they replaced.
chiefgrooveguruFull MemberNon of the reasons given explain why car manufacturers with all their resources choose narrow tyres over wide tyres to significantly reduce rolling resistance.
Because modern cars do not use narrow tyres, they are all on wide tyres when you compare across the 150 years of motor vehicles. Road bicycles are still on skinny tyres compared to the whole history of bikes.
Here’s a modern eco car and its tyres:
Here’s a 1930s racing car (and racing cars tend to have wide tyres for grip) and its tyres
Also, much of the efficiency loss when car tyres go past their optimum width for efficiency is due to increased aerodynamic drag, not rolling resistance.
RustySpannerFull MemberI think comfort has a big part to play too.
You’re more efficient when you’re comfortable, you don’t tense up as much and you pedal much more smoothly, for longer.Less mentally tiring too, which makes you happier as well as faster.
wilburtFree MemberNot when they are cheating efficiency tests. The manufacturers take a car that woyld normally have wide tyres and reduce its rolling resistance by fitting narroe tyres at above normal pressures.
If wide tyres dont add to rolling resistance why would rhey go to the trouble. Its not for aero fains because much of the testing is in a rolling road or low speed.
We also know that much wider tyres on the road offer considerably more rolling resistance but we are saying marginally wider offers less? Thats illogical.
I get it for comfort and grip off road or broken roads but on normal roads I dont think you’ll reduce the rolling resistance over 23/25mm 100psi tyres by going wider or lower pressure.AlexFull MemberI have no empirical data to bring to this debate 😉 However, I lent a mate of mine my Solaris Max running 2.8 tyres at 12 PSI last night. I’m normally a quicker climber than him, but he beasted me. Many other variables suggest this might not be statistically significant!
What was interesting tho – as this was his first ever ride on chubby tyres – was his insistence (and my refusal) they needed more air when he first sat on it, and his perception of how much quicker they climbed on the rooty/loamy trails we have here and how much trouble he had slowing the bike down once it got up to speed compared to his 650b bike shod with 2.3 tyres.
I was riding 29×2.35s. First time after riding 2.8s for five months. They certainly spun up to speed faster, but didn’t seem to roll better when I was chasing on the descents.
Still in other news, how fantastic are tyres compared to what we had a few years ago.
The topic ‘This wider tyres being quicker’ is closed to new replies.
