I tried it for a bit. Horrible stuff.
To be fair, it did fix a few punctures as advertised, but eventually I got one that it couldn’t fix. I stopped 2 or 3 times to reinflate to see if it would seal, and then finally gave up. So I tried to let the remaining air out so I could get the tyre off and swap a proper tube in, at which point it sealed the valve leaving me completely stuffed. I eventually managed to poke holes in the tyre with a safety pin and get it deflated, but it was a right PITA.
Add to that the fact that it gums up the valve at the best of times making it harder to pump, and every time you press the end of a presta valve to free it up, it spits green monkey snot at you.
I’ve only tried it with prestas, so I guess it might work a bit better with schraeder valves.
When you finally do give up with them, you’ve no idea how many punctures it has actually saved you from, and all the things that caused them will still be stuck in the tyre.
You still normally have to stop to pump the tyre up even if it does seal it, so you may as well sort it properly there and then.
