Viewing 33 posts - 1 through 33 (of 33 total)
  • This freehub body is made of cheese
  • buzz-lightyear
    Bregante
    No worse than my year old pro 2
    Rorschach
    No worse than hope,easton,crank bros etc or any freehub body made from aluminium.
    snaps
    My Pro2 was similar – just take the high spots off with a small file & It’ll be fine.
    davidtaylforth
    Thats what happens to aluminium freehub bodies. Doesnt matter what make it is.
    timbur
    More info required I think.
    How old, how much use, etc.
    buzz-lightyear
    18 months old. Not ridden that much as 70% of the time I prefer my HT.
    smell_it
    Are you wearing a shell suit?
    buzz-lightyear
    No. Poly hiking truggers
    Blue cheese is too soft.
    You should have used a mature cheddar.
    Rorschach
    dammit….dammit….dammit 👿
    njee20
    That’s nothing. Alu freehub bodies do it. It’s basically a cosmetic issue.
    Bregante
    You should have used a mature cheddar. parmesan
    stucol
    SRAM PG 990 Cassette. Problem solved.
    buzz-lightyear
    ” It’s basically a cosmetic issue”
    K. I’ll file off the burrs and continue
    Scienceofficer
    K. I’ll file off the burrs and continue.
    No. He meant your trousers…
    ;op
    gee
    Are you using a cassette without a sprocket carrier? i.e. anything other than Sram990/XT/XTR? SLX and other SRAM cassettes have too many individual cogs for aluminium freehubs to handle without scoring.
    As said, that happens to everything. I even replaced a King one after about 4-5 years of use a few years ago as it got so bad the cassette wouldn’t stay tight.
    GB
    Northwind
    DT seem a little tougher but Superstar ones are no better/worse than Pro 2s. Steel cassette meets soft alu freehub body, only going to end one way. Tidy it up and forget about it. A cassette with a carrier like XT, SLX, 990 etc will reduce the effect but it’ll still happen on the loose cogs.
    cynic-al
    Shame no one bar shimano properly addresses this issue.
    A steel insert on the leading edge of some splines would do it (or deeper splines like campag,)
    mooman
    when mine got too bad. I replaced it with the steel bodied version.
    baznav73
    Exactly what cynic-al said, why oh why can’t all the companys making alloy freehub bodys let in a steel strip on 3 or 4 of the splines problem solved and wouldn’t add any noticable weight and it wouldn’t take me 20 mins to get my cassette off.
    Northwind
    cynic-al – Member
    American Classic have a nifty insert thing on some of theirs, best of both worlds…
    TBH I reckon nobody else does it like Shimano because a Pro 2 with a steel freehub weighs about the same as an XT hub- people buy lightness then complain later about durability but they’ll still buy lightness next time.
    cynic-al
    Exactly Northy.
    It beggars belief to me that Hope lack mechanical sympathy in this way.
    Northwind
    It’s the customer sympathy that’s more lacking tbh, their way of dealing with it is to put a little bit of paper in the box that says “Fahgeddaboudit, it’s only cosmetic”. And to tell us we have to use XT or higher but it’s absolutely fine for Orange to fit deore.
    orangeboy
    You can use a chain whip to turn the cassette anti clockwise Somtimes to release it a little from the burs rather than just beat it off.
    Old hope Ti hub body’s also used to have the little label about Useing xt or xtr and used to mark up in much the same way.
    Just think of the hub body as a service item , when it’s buggered totally replace it
    andyl
    what you need is an all in one cassette and freehub…. 😉
    orangeboy
    Mmmm can’t wait for the hope one to be released. 9th bottom cog I need a moment lol
    mrmo
    Have a look at a Campag cassette hub, much deeper splines so the load is spread far better.
    o96192083
    looks fine
    njee20
    Mrmo, did you read the second part of Al’s post where he mentions Campag!
    Shimano tried when they first did 10 speed, but people moaned that you couldn’t fit 9 speed cassettes to their 10 speed hubs, so they gave up!
    mrmo
    njee20, no i read northwind’s quoting of Al’s post, that’ll teach me for not reading the whole thread…
    retro83
    cynic-al – Member
    It’s apparently because American Classic have a patent on the steel insert (according to Brant)
    http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144292
    http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144593
    cynic-al
    Interesting, I thought of doing that to the only aluminum freehub I had but then sold it for other reasons. I was gonna file a bit off then araldite in and file down spoke sections.
The topic ‘This freehub body is made of cheese’ is closed to new replies.
