Viewing 8 posts - 1 through 8 (of 8 total)
  • Thinking of changing forks – advice please?
  • gixer-chris
    Hi guys,
    I ride a 2008 Felt Compulsion, which has 140mm Rockshox Pikes. The head angle is quite steep, so the bike feels twitchy. Im going to get a shorter stem, and was thinking of changing the forks for 160mm ones, as my mate said that more travel would mean a less steep head angle, so less twitchy?
    With regards to the axel, as mine has a 15mm axel now, what happens/what do I need to change if I get forks with a 20mm axel?
    Thanks,
    Chris
    glenh
    69 degrees isn’t steep.
    JonR
    Can you get a 15mm axle to fit Pikes?
    foxyrider
    What length is your current stem? – Twitchy can also be d.t. wide bars & long stem – also your weight maybe too far forward with a long stem?
    steveh
    I’d start with the cheap option so try (borrow if you can or classifieds cheapies maybe) a shorter stem and maybe some wide bars. 160mm over 140mm forks will only take around 1 degree from the head angle so not a huge change. The cotic website has a little calculator thing for their frames but it gives you a good idea of what happens with the changes in fork length etc.
    thomthumb
    changing the forks to change the geometery isn’t always the best move imo. a longer fork will also raise the bb, which will make the bike less stable; counteracting what you are looking for being twitchy.
    pikes are all 20mm
    akira
    Shorter stem, wider bars even a bigger front tyre can all help without splashing out wads of cash.
    Or maybe a Cane Creek Angleset, not quite available yet but it’s a headset that allows you to change head angle.
    gixer-chris
    Nice one cheers guys! Will get a shorter stem 1st off then, as I think the Pikes are quite a good fork! And thanks for correcting me on the axel size 🙂
The topic ‘Thinking of changing forks – advice please?’ is closed to new replies.
