Besides from remap and big things would little things like air filter, plugs and anything else like this make any real difference to the cars performance?
Upgraded disks and pads could also be an option, you don’t need to go crazy, just go for the same size direct replacements, but performance ones rather than oem.
What is it? And where/ how do you drive. Usually changing it is the best thing! however if you have a half decent bit of kit in its class, then it’s tyres (changed to Mich pilots,as said above, on my current and a big improvement), suspension (change this on half our cars, significant difference), brakes (just pads on one of ours made a big difference) , maybe a re-map (this very effective on turbo diesels).
First things first, power doesn’t come cheap. Secondly there is no replacement for displacement. Thirdly better spending money improving the driver than the driven, if on a tight budget as skills are transferable to any vehicle. Gaining a driving licence only means you were better than the lowest standard required.
Car has (mostly) full service history. 80k 10 years old. Its a Vauxhal Vectra 2.0 turbo. Has good tyres on it at the mo (but winter ones). The car is in good condition. Just had new brakes hoses, track rods and anti roll bar links. Just wondering really. Little service due soon so was wondering if they make a difference then maybe I could do them.
If it’s a turbo, then it needs to breathe easy. Plugs and stuff are not going to make even the slightest noticeable difference.
1. Induction kit. No idea what’s about for Vectras but something that looks like this should do the job:
2. Higher flow intercooler
3. Larger bore (i.e. free flowing) exhaust
4. Decat (not road legal) or performance cat (possibly road legal)
5. Boost pressure regulator, about £15 on eBay for a cheap grainger valve type. It’s a delicate thing, boost. You’ll need a decent boost gauge for fine tuning if you don’t want to pop your engine.
6. Possibly a fuel-cut defeat chip thing, depending on how your ECU reacts to higher boost.
Probably a good idea to look at improved cooling/ignition/suspension/brakes/tyres at the same time.
I wholeheartedly agree with many of the above posters though: is it worth it on a Vectra?
Fifth Gear did some really basic stuff to a Corrado, plugs, air filter, oil etc and fuel stuff and measured the power after each bit. Did make a difference.
Chip it? As in one of those wood-chipping machines… 😉
Change it if you’re serious, otherwise you’re just polishing a turd.
Having had a 3.0, 4 cylinder, displacement has a lot going for it. Run a few turbo cars too, they’re good with some big gains possible, but not the same.
Decided against Stage 1 for the Octavia (150 to 220’ish). Crap VAG brakes would need attention, it handles like a bouncy castle at pace due to lifted 4×4 suspension and it’s approaching 200k. Starting a process of polybushing is removing a lot of slop.
Don’t want to do anything nuts, just wondered if anything within the realms of normal service stuff. Will need an exhaust soon.
I’ve always found performance exhausts to be cheaper than manufacturer replacements, and it will certainly help. After that, performance air filter rather than full replacement induction kit. Between the two you might just eek out an extra 5-10bhp. £15 grainger valve for boost control and a £35 boost gauge would then potentially add another 10-20bhp, but without supporting upgrades you run the very real risk of either running too lean = engine knock = kaboom, or just too much boost for your head gasket = kaboom.
