34T Vectoix Chainring with 11-32 9 speed using an SLX M662 Medium cage mech here, Chain retention is pretty good (Not perfect) on my HT…
I have shortened the chain as much as possible, in the two months since I fitted it I’ve dropped the chain twice so its an occasional annoyance rather than a constant issue, the main issue is really as short a chain and as much tension as is practicable without that clutch to arrest the bounce I think, interestingly I think in both instances where the chain had come off I’d shifted down to the smallest sprocket, so chain tension was at a minimum…
The range of gears suits my local riding, but if I head to bigger hills I’ll admit I’m struggling a bit without a Granny ring, so I’m in the process of assembling a cheap 1×10 setup with the £20 M615 mech Merlin were flogging last week and a wider range cassette, otherwise I would be happy to carry on using this set up for a fair while…
