Ok, this is driving me nuts – We’re new to caravanning & currently loading it up (how I miss the motorhome – chuck it all in & drive).
I’ve been trying to sort the nose weight out – my yeti has a tow-ball weight limit of 85kg. When I measured the van’s nose weight it was 110kg and bent the base of the scales..! This didn’t seem right given there was nothing particularly heavy at the front (even the gas bottles are in the centre over the axle), so I’ve been wading through the many caravan forums looking for clues. I’ve had enough.
I did happen upon some advice saying that the nose weight should be measured with the hitch at the same heights as the tow-ball. My scales were a good 12cm lower so I chocked these up to the correct height and measured again – lo and behold it dropped 10kg by magic. WHAT IS GOING ON?
Thinking I’ve been losing the plot I used my father in law’s scales and measured again – same result it loses weight by lifting the nose. In other words, the point at which the hitch makes contact is now higher and results in a lower weight. Why is this? Also, nothing moves in the van – its all static & well secured.
