i also place much lower than expected and am wondering if this is part if what I need to improve for the next rounds to carry more speed or just bring my HT instead.
Is this the first time you raced at Thetford?
The terrain is quite unique in the way that it looks easy, but because the forest is sand based its actually pretty tough esp if you arent used to riding constantly ‘power on’,i would say the bogging down is probably the stodgy condition of the trail this time of year as much as anything else. Its just sapping away at your legs.
A hardtail might be partial soloution on the next round as Brandon is much smoother and there are more climbs, but for the other sides of the forest stick with the full suss, unless its pouring with rain you can get away with racing ralphs quite happliy, high tyre pressures, make sure your shock pressures and re-bound are set correctly.
Most importantly try to train at Thetford, Tunstall or even Rendalsham which mimic Thetfords sandy stodgy conditions.
Good luck
