Timing a Fox TALAS is a Major PITA.
Those of you that have tried will understand how intricate the process is.
if you follow the fox instruction it is, trial and error method is best. Put the talas rod in position (best guess) and rebuild the lever without the retaining ball bearing and test, adjust the rod until it works properly. Once it's working as designed re-install the lever with the retaining ball bearing.
