Viewing 40 posts - 1 through 40 (of 43 total)
  • The results of all those woodwork/DIY threads…
  • Duane…
    Asked a whole bunch of questions before Christmas – thanks for all the help!
    I made a simple jewellery/trinket box for my girlfriend for Christmas (her initials are MB)
    And this desk lamp, with a plywood body and cement base
    Pretty happy with both!
    tails
    Cool is the shade made from ply as Well?
    Duane…
    Yup, single sheet of 0.4mm ply.
    mactheknife
    Awesome, i really like those 🙂
    br
    Good design and good skill.
    kayak23
    Fantastic. Love the lamp. 🙂
    globalti
    How did you bend the plywood?
    lemonysam
    There’s a chap working in newcastle who makes lamps very like that but about 7 foot tall. Like it!
    CaptJon
    lemonysam – Member
    sounds cool, got a link?
    AlexSimon
    Nice work!
    Like the sketches too.
    schrickvr6
    I love lamp.
    cynic-al
    OP did you get your hole?
    tinybits
    I get how to bend the plywood for the upright, but how did you do it for the shade?
    Duane…
    Edit
    dooosuk
    Love the lamp!
    Del
    Very impressed by that, good job!
    method please!
    Duane…
    Some pics of making the lamp;
    Mold for concrete, with embedded bolts – leaving length exposed to put nuts on
    Glueing the lamp shade. Masking tape to try pull it vaguely circular (not overly successful)
    Glueing the main body, while clamped around mold. 5x 2mm sheets of ply, with a layer on either side to protect from the clamps.
    Disk glued into lampshade to give rigidity and a glueing surface
    Glueing lampshade to body
    AlexSimon
    Very nice – where did you buy the ply?
    hs125
    Brilliant results. Were there any prototypes (i.e. cock ups) along the way?
    Harris
    Good skills Duane. There are shops that would charge the earth for that lamp.
    Like here and here
    alpin
    ^^ Why do people pay so much for a lamp?
    Acquaintances of ours have lots of “designer ” stuff that just looks like stuff.
    Nice work Duane…
    partickbateman
    I’d buy the lamp!
    gavtheoldskater
    very nice.
    doof_doof
    Great work on the lamap.
    Reminds me a little of this one:
    kayak23
    alpin – Member
    ^^ Why do people pay so much for a lamp? car?
    alpin – Member
    ^^ Why do people pay so much for a lamp? pair of jeans?
    alpin – Member
    ^^ Why do people pay so much for a lamp? (i) phone?
    alpin – Member
    ^^ Why do people pay so much for a lamp? bicycle?
    Nice work op. Enjoy the ‘making-of’ pictures, and like the home solutions to clamping pressure… Looks a balancing act. 🙂
    blaggers
    Nice lamp, it might be worth getting one of the LED bulbs that IKEA,etc sell. They give out no heat at all (you can touch the glass with your fingers which feels a bit weird after growing up with incandescent bulbs), so would prevent the wood discolouring due to heat.
    cynic-al
    cynic-al – Member
    shorn
    That’s awesome and very inspiring!
    Duane…
    alexsimon – thin ply was tricky to get hold of, ended up getting it from a model shop.
    hs125 – had a couple attempts at making the base – I initially used a normal cement/aggregate mix, which turned out way too crumby/didn’t set quick enough. Changed to quick set cement (no aggregate) – which is perfect for this kind of thing! Only other hiccough was dropping the lampshade and chipping the edge, so had to do a bit of glueing/sanding. Was my first try at laminating and it worked out pretty well which I was happy about!
    doof doof – indeed, pretty similar, I did actually design this one before I first saw those lamps!
    blaggers – good shout, will look into it.
    cynic-al – huh?
    Malvern Rider
    i love lamp. Nice work on both counts, inspiring!
    vorlich
    Love the lamp OP. How did you round off the concrete?
    Duane…
    Metal file and sand paper! It is pretty easy to work with. Then coat of diluted PVA to seal it.
    Duane…
    Wall clock I made this past week.
    AlexSimon
    Cheers, noted
    Duane…
    Quick and simple laptop stands from a bit of old pallet wood.
    nickc
    Love that lamp. Very cool.
    goldfish24
    Nice finish on that pallet wood for the laptop stand! What did you use/how?
    lemonysam
    lemonysam – Member
    sounds cool, got a link?[/quote]
    I thought it was this chap but I can’t find the exact thing I’m thinking of on his site he makes some similar though so it may be that it was a one off in his studio or it might have been one of the other guys in Ouseburn.
    http://www.graham-warren.co.uk/
    Think of a kind of combination of these ones of his:
    Duane…
    Goldfish – sanded down and a few coats of dark oak varnish – nothing fancy!
    Macavity
The topic ‘The results of all those woodwork/DIY threads…’ is closed to new replies.
