What is the most boring bit on a mountain bike?
I just can't get excited about seat posts, or bottom brackets.
What's the most boring bit of your bike?
headset spacers.
headset spacers.
you can get carbon ones man
the bolt that connects the seat to the seatpost would be my suggestion
Gear cable end crimps
Also the most exciting bit if it suddenly goes missing
those little metal shrouds you crimp onto the end of your gear cables, they're pretty dull
Bolts don't count!
The rider when they start banging on about how much weight they saved by fitting ti bolts everywhere... Who cares.
All the bits are pretty boring in isolation. It's when you stick em together that they become interesting!
Inner tubes. That's why I ride without them.
quite an amazing thing the bicycle, lots of simple bits working in harmony to furnish the user with fun and transportation.
so none of it
BLASPHEMY! nothing is boring on a bike.
But some of the riders are.
Just looking at the pictures of my bikes on the computer and I can confirm that no part of any of them is boring.
Scrutinised the brake adaptors, ferrules, spacers, nipples etc but no I find it all amazingly interesting.
Seatposts and BBs are off the scale
headset spacers, cable end crimps, bolts, even the humble aportace spring...all serve a purpose. Valve caps, on the other hand, do not. BURN THEM.
Reflectors that never make it past shop door on new bikes that never knowingly end up on the road
X2 for reflectors. On most serious MTB's they will be taken off and end up in landfill. Also the ones that come on new Shimano SPD's. Doesn't go with the green transport message.
Serial number on the forks.
I have Merlin remove mine before delivery.
Is Merlin your butler?
The little nut which holds the valve stem in place, I thought they were boring when I didn't need them, now I do (ust) they are even worse!
Nipples
the bearings on a full suss, no bling or excitement to be had..
Just me who actually enjoys crimping cable ends then...
once saw a 6 page seatpost grouptest in mbr.
WOW
They do, I lost all the air in my shock once because it didnt have a valve cap and some gritty mud got in there and somehow opened the valve.
Fantastic when you need to pump up a tube from flat the valve doesnt disappear inside when connecting the pump.
Ceramic bearings!
Just screw the valve tight when you've finished with the pump!
but they come in pretty colours too!
Cant really do that with the schrader valves they put on shocks can you.
non-wheel valves. Odd, but good call.
The Rider.
verses - Member
No, me too, because that usually signifies the build is done and bike is ready.
No, me also
aportace spring
headset spacers.you can get carbon ones man
I reckon brakes are boring due to the fact that they make you slow down.
