Viewing 13 posts - 41 through 53 (of 53 total)
  • The Monty Hall Problem – a simple maths/probability problem for you all……..
  • gravitysucks
    poop example gonefishin…. there are millions of combinations on the lottery to simplfy it to win or lose isn’t really the same
    Crispo your basing it on the fact of just looking at the two doors.
    Think of it this way, the host has to show you 998 goats. Before he show’s you them either he has the car in the 999 doors he has or you do in your 1 door. What is more likely?
    allthepies
    all the pies, same principal but even more important to switch
    No need to tell me 🙂 I understand the need to swap, my extrapolation example was an attempt to convince the errr, unconvinced 😉
    miketually
    If anyone doesn’t believe you should switch, I’ve a tenner here and three cups. Bring your own tenner and we’ll play.
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    Cougar
    One tenner three cups, it’s the next Internet sensation!
    TrekEX8
    gravity sucks – I don’t know, which is more likely??
    Am I missing the point here? Surely there are now 2 doors, and there is no more likelihood that the car is behind one or the other? So, how do you increase your chances of winning by switching to the other door with equal probability of having a car behind?
    RobHilton
    Go from 2:40
    [video]http://www.youtube.com/watch?v=mhlc7peGlGg[/video]
    miketually
    Yes?
    There’s a 2/3 chance that there will be a car behind one of the two doors that you didn’t choose first. Effectively, you’re being given the chance to choose both those doors instead of your first chance.
    So, you’re twice as likely to win the car if you switch.
    GrahamS
    Well if that messes with your head then try this old thread for a probability reality check 😀
    RealMan
    Cougar
    If the premise was simply “one of these doors has a car behind it, which one?” then you’d be right. But that’s not what’s been set up.
    You’re presented with two doors. However, the odds of winning have been stacked by previous events; ie, the two doors are not equal.
    At the start of the game, you pick a door and have a 33% (rounded) chance of being a winner, yes? Think about that. You can now do what you like with the other doors, add more, remove one, paint them pink, set them on fire, write “here be goats” on them; it does not, can not change the likelyhood that your door contains a car or a goat – it will always be 33%, that was the choice you originally made.
    In the second round, you’re given another option. You can keep your existing choice (33% chance of being right, remember) or you can trade that choice for another door which, now that we’ve removed an obvious wrong choice, represents all other odds other than the one you already hold. 100% – 33% = 67%.
    TrekEX8
    Thanks Cougar, however…..at the beginning, the chance of winning was1/3. If the host opened two doors, to reveal goats, would the odds still remain at 1/3 that opening the remaining door would reveal a car?
    Farticus
    Simplest to illustrate by going through all the options.
    Assume you pick the one in bold in each of the 3 options below. Whatever you choose, Monty opens a goat* door (the one crossed out). So, sticking means you win 1/3, switching means you win 2/3.
    G G C becomes G G C. Stick = Win. Switch = Lose.
    G G C becomes G G C. Stick = Lose. Switch = Win.
    As far as i know this should work with sheep, cows or anything else. I’m surprised questions weren’t asked about Monty’s interest in goats.
    I_did_dab
    this was demonstrated on BBC Horizon with toy cars and toy goats. One player always changed the other always stuck with the original choice. After 100 goes the pile of cars for the always changes was much bigger than the always stays in line with the probability theory…
The topic ‘The Monty Hall Problem – a simple maths/probability problem for you all……..’ is closed to new replies.
