Any advice for a technical numpty on autosag settings.
When I bought my camber evo I set the suspension up manually and everything was hunky-dory. No pedal strikes, all felt good. But was a bit lazy about checking suspension – largely due to the fact that I lost my shock pump 😳
Bought a new one recently and checked the front 😳 a bit down and then decided to go with autosag for the rear. First couple of rides it felt a bit harsh – almost like a HT again – so let some out of the rear shock. But only a tiny amount while riding at Swinley. Just with my finger in the red bit (tech term there!)
Then today I was riding round Surrey Hills and was getting several pedal strikes, one which almost had me off. Also noticed that I am going though both suspensions a lot, even when climbing???
So I assume that I have let too much out of the rear shock – excuse the stupid question, but would that be correct? If so, I assume again that the solution would be to add a few more psi on top of autosag setting. Again does that make sense?
I am not a racing whippet if that makes any difference.
Excuse any bad use of terminology – tech stuff is not my forte.
Anyone got quick suggestions?
Reading this before a hot bath!
https://media.specialized.com/support/0000040894/0000040894.pdf
