Viewing 40 posts - 1 through 40 (of 58 total)
  • The Island of Japan as moved!!
  • can-uk
    ?”The earthquake was so powerful that Italy’s National Institute of Geophysics and Volcanology said the Earth’s axis shifted 9.8in [25cm]. The US Geological Survey said the main island of Japan had moved 7.8ft [2.4m].”
    I know that there are many, many more important things to consider at this time.. but what are the implications of a country moving by nearly 8 feet??
    GPS issues, Maps & Charts?? what else?
    Article here:
    http://www.telegraph.co.uk/news/worldnews/asia/japan/8378631/Japan-earthquake-tens-of-thousands-missing-as-full-devastation-emerges.html
    TheFlyingOx
    It’s also sunk by 70cm, meaning a lot of the water we’re seeing covering coastal towns is likely to be permanent.
    Hairychested
    Terrifying reading, highly informative at the same time, thanks for the linky.
    M6TTF
    shorter flight times?
    kaesae
    I believe that this is just the start and that we will see more and more earth quakes of this magnitude and greater, as well as eruptions, flash floods and other extreme weather.
    Is it not a strange coincidence that there is a lot of activity in Iceland
    http://www.telegraph.co.uk/news/worldnews/europe/iceland/8311924/Icelandic-volcano-set-to-erupt.html
    as well as on the other side of the earth in Japan and the surrounding area ❓
    Just a thought!
    simonralli2
    I think we all moved didn’t we? Didn’t this shift the earth’s axis or did I dream that last night?
    DrP
    Very narrow minded there. Some flights will be LONGER…… 😉
    DrP
    Duke
    Or longer flight times, it’s all relative.
    We are lucky to have had one of the longest periods of tectonic stability in the earths history that has allowed life to evolve as far as it has, i.e. us.
    Also, since Chris Columbus “found” the Americas (Although lots of evidence suggests the Vikings got there before him, along with tall white haired Europeans) The Atlantic ocean has widened by about 25m.
    The earth is a dynamic place. What’s happening/happened in Japan is both horrific and amazing. We know people in Komono, Mie. Not sure how affected they are yet.
    Xylene
    It’s the supermoon
    The end is nigh
    yossarian
    Don’t worry, people of Japan – help is at hand via the Lady Gaga Japan Earthquake Relief Wristband
    monkey_boy
    B.A.Nana
    Reuters are reporting this morning, during the night (our time), these faint transmissions were seen on televisions in parts of Australia, New Zealand, South Africa and Argentina.
    sweepy
    What possible bloody use is that, its not even got a hologram
    allthepies
    as it ?
    Barelyincontrol
    I think it would be better for the people of Japan, and indeed the world, if ‘Lady’ Gaga just stopped. That would free up a load of money for the people of Japan.
    paulosoxo
    Barelyincontrol – Member
    POSTED 9 MINUTES AGO # REPORT-POST
    Internet reports of her donating $16,000,000
    SurroundedByZulus
    Wife told me that the earth moved this morning. Was about to get divorced until I read this. Panic over.
    ernie_lynch
    It does seem a lot, but I had always understood that earthquakes are caused by continents moving about, and as it was a massive earthquake, it shouldn’t come as any great surprise.
    And I wouldn’t worry too much about the Moon moving away from us at 3.8 centimetres per year either. Or the fact that Greece is slowly sliding into the Mediterranean and will eventually disappear. Yes, the World will be a very different place in a few billion years. But we’ll adapt. Somehow.
    MrWoppit
    Did you really, ernie? How peculiar.
    epicyclo
    Every now and then the Earth reminds us that all our efforts to pollute and damage it are amateur.
    Duke
    I refer my honorable gentleman to the answer I gave some moments ago.
    ernie_lynch
    Yep Woppit. That’s what I was taught at school anyway…..the connection between earthquakes and plate tectonics and continental drift.
    Why ? Do you want to make some pedantic point suggesting there might be other causes ?
    MrWoppit
    There was me thinking that it was the plate techtonics that was causing the eathquakes.
    Or perhaps Richard Dawkins.
    ernie_lynch
    So that’s quite different to saying “earthquakes are caused by continents moving about” ?
    Plate tectonics isn’t anything to do with “continents moving about” ?
    Hahaha…….what a fool I am ! I can understand why you thought “how peculiar” ! 😀
    MrWoppit
    Um, yes.
    ernie_lynch
    So the claim that when continental plates move some of the energy is released as earthquakes is false then ?
    There is no connection whatsoever ?
    How do you know all this stuff Woppit ?
    GrahamS
    From earth-shaking natural disasters to petty bickering and pedantry in 25 posts?
    Good effort boys 🙄
    ernie_lynch
    Good innit ? 😀
    MrWoppit
    ernie_lynch – Member
    Yes. When the techtonic (or “continental”) plates shift, energy is released that causes earthquakes.
    It’s the plates that are shifting, not the “continents”….
    TheFlyingOx
    Bit of perspective for you pedantry gimps:
    Before and after satellite images.
    But you’re right. We must first bash out the finer points of terminology to be used in describing what happened before we can even contemplate showing a bit of empathy for the affected.
    TheSouthernYeti
    Woppit FFS! 😆
    MrWoppit
    Strangely enough, I haven’t read about any religious pundit claiming it was god’s judgement because the Japanese don’t worship the correct deity, or somesuch. What CAN be keeping them quiet?
    tankslapper
    Funny how global warming had absolutely nothing to do with it…….
    So let’s see Mother Nature 1 Climate Change Idiots 0?
    molgrips
    Most earthquakes, although it’s more complicated than that.
    The plates are shifting all the time building up tension – this then is released along certain plate boundaries in sudden movements. There are lots of kinds of fault though.
    Scuse me?
    tankslapper
    The point is that we may have more to worry about than global warming
    Anyone else notice the amount and magnitude of the earth movements around the Pacific rim over the past few years? My guess is we are about to see a super volcano – so the global warming debate will be ever so slightly null and void. This is just the start
    Thanks for all the fish
    TheSouthernYeti
    Tankslapper – can you edit that until I’ve had the chance to go and buy all the baked beans and tinned meat in the local area?
    Thanks.
    Yeti
    Cougar
    Oh, this should be good. Hang on a minute lads, let me get some popcorn.
    molgrips
    Right, but which things can we actually do something about?
    Oh, let’s all guess stuff! My guess is blue! Ooh this is fun!
    tankslapper
    Bite dam you! BITE!!!
The topic ‘The Island of Japan as moved!!’ is closed to new replies.
