You can’t catch flu from the jab. It will protect you against the strains covered by the current year’s jab (the ones considered most likely to infect you that given year). It won’t protect you against the common cold, but the common cold is prevalent around the time the flu jabs are administered, so not a suprise if you get a cold not long after having the jab (you would have had it anyway). If you think that the common reactions are bad, you need to MTFU. A mild ache in the arm is common – I’ve had worse when Mrs T has inadvertantly brushed my arm with a feather duster on her way to swiping a spider’s web. OK, you may feel mildly off colour when you’re immune system kicks into action (as it should) and there’s nothing wrong with that, but MTFU. If you really think that’s bad, then maybe a dose of proper flu will help to remind you what being ill is all about. Uncommon reactions are exceptionally rare. And as for
Linked to Guillain Barre, Erm, no thanks, I’ll chance the flu
You’re kidding, right? Get a grip and a sense of perspective. If you’re eligible for the flu jab, then you’re MUCH more likely to fare badly having sustained the flu that you ever are from the jab.
We haven’t had a really serous outbreak of influenza for a long time and there is a lot of ignorance. Worth reading about the 1918 Spanish flu outbreak on Wikipedia. When we get a very serious form of influenza again – and we will – you’ll be queuing up at the door of your local surgery to demand immunisation and not worrying about obscure and rare side effects. Trouble is, when there are false alarms and “swine flu doesn’t seem to be as bad as we thought it might be”, it tends to breed complacency.
I haven’t got time to elaborate, but you may want to look into the Guillan Barre link in more detail. It’s by no means clear cut either.
Oh, and I’ll take my chances with the jab, thank you.
