Tyres/tubes for me.
Rebuilt a wheel on my commuter with the nipples in a pot of old fork oil (this in itself is not a bad thing) but needed for work the next day, quick wipe down, rim tape on and tyre up. A week later the oil from the nipples has soaked through the cloth (velox) rin tape and perished the innter tube in a pretty spoke hole pattern all the way round the tube. Of course i did not realise this until the front unexpectedly flatted at 40mph down a 13% hill with traffic lights/queue at the bottom. 😯
Also on another wheel, using slightly too narrow plastic rim tape in road wheels means no matter how hard i tried to line it up righ there would always be a flat tyre by the next morning as tape slips over and 100psi tube nips itself on the edge of a spoke hole. Even glue doesn’t work.
Many years ago i torqued up an old octalink crank to stupidly tight trying to fix a creak that was actually the bottom bracket failing. Did it so tigh the threads stripped when i tried to remove it with a crank puller: had to dremel it off but did prompt purchase my first set of ht2 cranks which are still going and still great.
