DE shaving is too slow and faffy.
Kings of Shaves shaving serum (the green one), Gillette Hydro (the battery powered vibrating one) and the Hydro 3 blades.
Each blade cartridge lasts ages (weeks) and it’s lubrication helps to start and then when it runs out you just use a bit more shaving serum.
The 3 blades as they clear better, but the powered handle from the 5 bladed version as it is useful when clearing those pesky bits on the neck.
The Hydro doesn’t have that stupid paper based lubrication strip that just about every other type has, and which is the bit that ‘wears’ out first and causes all the drag that makes you think the blades are blunt.
I’ve done most of the main ones, like Mach, Fusion, and this is much better.
Also got a decent DE but life is too short…
