• This topic has 3 replies, 3 voices, and was last updated 9 years ago by JoeG.
Viewing 4 posts - 1 through 4 (of 4 total)
  • That red bit of plastic to cover exposed cables from SRAM Flak jacket sets……
  • dizcostix
    Where can you buy extra lengths of it from?
    epicyclo
    Got to a place that sells air tools and equipment. They use PTFE tubing, and you can get it in small diameters. (I use it as a inner cable friction lining). You may not get red, but you’ll get something suitable.
    If you want to give uncoloured tubing a colour, it should be possible to dye it with Dylon.
    Edit:
    Just found this from SJS Cycles
    dizcostix
    Perfect thanks! black will be better than red!
    JoeG
    Jagwire seal liner
    I use mine with Shimano endcaps, minus the rubber boots.
The topic ‘That red bit of plastic to cover exposed cables from SRAM Flak jacket sets……’ is closed to new replies.
