i did it with the deal extream ones (Q5, 240lumens) but they have a removable center section so no need for the cut and stick technique.
Just driled into the side of the shortened body (used a 1mm as a pilot then went crazy with a 2.5mm), fed wires through (salvaged from an old MG midgets wireing loom), soldered one end tot h back of the LED (DX ones are a CNC’d heatsink which threads int the body, with the LED circuit board mounted on the front and the +ve terminal on the back). Twisted and crimped the -ve wire to the spring. Re-assembled the two halves (add enough opposite twist befor hand to accound for the screwing together of the two halves.
et voila, 1 58g light unit. 2 of them mounted as far back on my helmet as possible is near unnoticable (mounting them further forewards seems to make them more pendulous). best bit has got to be the fact that the switch/regulators are all left intact so they function perfectly.
Got 2 more to play with at some point, would like to mod them to make the central spot beam a bit wider, anyone got any usefull advice for that?
The only downside of the DX lights is they have overheated and dimmed occasionaly, but that seemed to be only o the first ride, they havebeen finr since and withthe mods its never happened.
Light units weight 58g including a 2cm section of grip pushed over the hole to shield the wire from any wayward branches/rain.
