I am running TF Tuned mounting DU bushing system.
I have replaced my bushing before with a couple of different types of bushing and never had this problem before.
My suspension has been feeling a bit stiff for a while now and I seem to have to run lower air pressure to get good movement from rear shock.
So i decided to investigate.
The TF Tuned DU bushing has a rubber spacer either side of the shock eyelet and then an aluminium spacer against the frame and rubber spacer. When i removed the shock i notice the DU bushing had moved and no longer was flush with the eyelet, so on one side it was about 1mm or more sticking out of the eyelet. Obviously with a solid space like some of the aluminium ones or nylon ones this would not be possible but it seems to have moved out to one side because the rubber spacer is so soft.
Q: Is it only moving out because the rubber spacer is so soft or is it moving over because of some other alignment problem etc.
Q: Is it design to do this to allow for better movement?
Q: Would i just be better swapping back to a solid bushing spacer?
I am concerned?
I have reset it all in vice so DU is flush with shock eyelet and gone on two rides and checked again and it has same issue again. Other end of shock has Fox bushing so no issue at top end.
I also serviced rear shock at same time so this could have been what improved the plush ness of my shock, not sure. Shock stll felt good at end of last ride so i’m thinking maybe service sorted it.
But why would this DU bushing move out of alignment with shock eyelet?
Thanks in advance guys
