Great forks, but trying to slim down the bike a bit.
2007 Magura Wotans
160-120mm Travel (Remote Adjust)
Air Spring
20mm Maxle Bolt-Thru
The decals have lifted off a bit, and one of them subsently now says 'WOT'
One of the lower stanchion retaining bolts snapped whilst servicing. Its been replaced with the correct item (its a hollow one that the damping adjustment runs through) but had to drill the remains of the bolt out - the threads got slightly damaged and hence i've theadlocked the new bolt in - belt and braces. Been like that for a year with no problems.
Travel adjust, damping adjust, lockout-esque thing, all work fine.
Post mount, 8" rotor.
£150 ono or swap for some bolt thru air Revelations
Tim
