Ok, so I bought this hardtail frame in small size. The seller lad was very helpful and, after consulting the manufacturer, kindly suggested that it should be ok for a guy my size. But I would like some more reassurance from people of similar size/setup.
I’m 5’9″ and, although companies regularly recommend medium sized frames, I almost always end up happily in large ones. That’s for road bikes. I like the space, the stability and, honestly, I find they are plain prettier. Now, being totally new to mountain biking etc, I understand that in a hardtail one needs maneuverability and quick handling above all, but a small? a small? Will it not be too cramped? (add to the equation that I have a 60mm/0 deg stem I’m planning to use and I always prefer riser bars over flat ones). So, what do you good folks think?
Cheers.
