- This topic has 51 replies, 28 voices, and was last updated 12 years ago by Rik.
tell me about surly cross checks and anything else similar thats as veristile..
karnaliFree Member
after a new cross based frame for the commuter come winter bike.
main use will be commuting, other uses will be trailer pulling, may 2 cross races a year, the possibility of the 3 peaks race.had a winter comuting on a tricross single speed couple of years back and enjoyed the simplicity of the ss and lack of winer cleaning that was needed. Thinking about getting another 2nd hand, but like the versatilty of the cross check in that i can put gears on for the summer and use it for pulling the trailer and wet weather road riding aswell
is it a good choice asa frameset for this and what else compares to it? poss the mk2 kaffenback but is that going to be disc only??
ta
marka.Free MemberI love mine, which I bought as a complete bike. It’s used both on and off road. For commuting (its main use) I’ve changed the tyres, and added mudguards and panniers when required.
If the gears died tomorrow, I’d definitely consider Alfine + drop-bar shifters. It’s nice to have that option there.
The only thing I would change, though, is to have disc brakes.
When I bought it (over a year ago) the only real alternative was a Kaffenback. The Surly won mainly because I was able to test ride one.
Fresh Goods Friday 696: The Middling Edition
Latest Singletrack VideosFresh Goods Friday 696: The Middlin...tommidFree MemberMine is ace. Its fully racked up. Mudguards in the winter. Ridden it off road a few times on trail centres with cross tyres and its brilliant.
Ticks every box, commuter, CX, hybrid, 29er, road bike, you name it.corrodedFree MemberI’m also looking at a similar bike. Currently liking the look of the Genesis Croix de Fer and the Peregrine.
SpinFree MemberKaffenback ain’t no crosser. You’ll struggle with anything fatter than 32mm rubber and not a lot of clearance at that.
If you want versatility then the Cotic Roadrat is neat. 26″, 700c, disk brake, rim brake (700c only), rack mounts, single speed, geared, upto 45mm rubber with decent clearance on 700c (you can even call them 29″ if you want).
‘taint fancy though.
charliedontsurfFull MemberNothing beats the surly cross check for versatility:
Fixed
Ss
Hub gears
Mech gears
Mudguards
Full on racks
47mm tyres
Tour
Race
Commute
Go to the cake shop
I rode mine to Belgium and then raced it.gazcFree Memberi use mine for everything and it’s my most ridden bike. rack/guard/touring tyres with full panniers for commute/tour/shopping, trailer for hauling big stuff/beer, 35mm knobblies for the odd CX race and trail centre bash. currently singlespeeded and in CX mode for a local summer CX midweek series but happy commuting on it like that too
seems comfortable with anything you can chuck at it, even found it at home on the (small) jumps on our local trails/bmx track too 😀
only gripe i have is i only have one of charliethebikemongers white ‘my dandy horse brings all the boys to the yard’ stickers on it… 😉
marka.Free Membercorroded – Member
I also looked at those. I just didn’t like the Croix de Fer, even though in theory it’s ideal. It was heavy and there wasn’t masses of tyre clearance, so CX tyres and mudguards wouldn’t fit. The Peregrine is gorgeous but was much more expensive.
YMMV, of course.
mochaFree Memberit’s all been said! commute, tour, race, fixed, free, gears – do anything, go anywhere – if you could only have one bike, etc.
nedrapierFull MemberI’m happy with my Peregrine. It’s a compromise,obviously, heavy for a road bike and not exactly spot on for technical trails either. But I love the versatility. Rear rack and guards to come for the commute, which will make it less pretty, but it will be nice getting to work without a sweaty back.
I love the singlespeed after being a skeptic for ages, but really enjoyed it. I hadn’t realised how much brain space thinking about gear choice takes up, and it’s really nice just pedalling without needing to bother! Went to 1 x 9 for a SDW jaunt.
Can’t deny it’s pricey, though.
Singlespeed Commuter:
Off Road:
Tarty FunTime:
Big-DaveFree MemberHad a Cross Check for a couple of years now. I built it up myself and it has to be the bike I ride the most. It really is as versatile as the blurb would have you believe. I looked at the Road Rat and Kaffenback but the extra clarance for wider tyres did it for me.
Its no where near as heavy as some people would have you believe and the handling is brilliant. When I first built it up I ran it with road bike wheels and tyres and proved itself to be fast and stable through the corners. I’m now running touring wheels and tyres as I like bouncing across the rough stuff on it from time to time. I’ve had 38mm tyres and mudguards on there with no clearance problems and it could take fatter rubber.
Whilst it isn’t a flashy looking frame the build quality is spot on and the price makes it pretty good value for money IMO.
The Peregrine is a lovely bike, I have a Swift so I know how good the frames from Singular are, but it is pricier that the Cross Check and can’t be run with rim brakes. For some people thats a good thing, for some its bad.
You could always try a Karate Monkey if you wanted to be a bit left field. I’ve got one of those as well and its even more versatile than any of the other options discussed here. You can run whatever drive train and brake combinations you want with a KM.
Digger90Free MemberCotic X is versatile.. OK, not ideally single-speedable but you can use an X for Road, CX races, Trails, Commuting, Faffing about on
It’ll run slicks, CX knobbies, Monster Cross, 29er etc and can run either Disc Brakes or Canti’s.
That’s why I bought one.
But a medical problem means I did not even get to ride it and it’s now up for sale if anyone’s interested.
http://www.singletrackworld.com/forum/topic/cotic-x-56cms-brand-new-2
STATOFree MemberI have a CC, great bike, picked it up SH off the classifieds here as i thought £300 new was too steep, how wrong i was. If it broke tomorrow id not hesitate to buy another immediately. Infact, its looking a little tired after some serious abuse and neglect over winter so i might just buy a new one anyway.
Previously i had a pompino, nice bike, great bike infact. Not as versatile as the CC but very capable and snappier handling, the CC beats it tho, its just such a nice bike to be on.
There has never been a time ive ridden it when ive thought i wanted to be on something else. I did buy a Surly LHT for touring/commuting tho, as the CC was just too much fun to nail down in touring mode all the time. So now it stays in SS-cross mode, ready for commuting/ cyclocross/ ragging in the woods/ long day rides/ anything you could want to do on a bike.
karnaliFree Memberstato go for a new one and hey you could sell me thold one depending on size!!!
my only hesitation at present is trying to find one 2nd hand and also looking to see whne and how much the mk2 kaffenback is going ot be as it look slike having bigger clearance than the original one
antigeeFull Memberbeen waiting a while for on one’s uncle johns to come back into stock
mainly because can go and try for sizekinesis tripster is another option but no one seems to get excited about how they ride?
any idea how the cross check sizes up ? i’m 5ft 4 with a 29″ inside leg
matthewlhomeFree Memberi love my cross check. It is heavy though, but doesnt ride heavy – only a problem for lifting over gates really.
I very nearly went for a karate monkey, but wanted to be able to use the road spaced wheels from my old cross bike. If i could only keep 1 bike, it would be the cross check. As charlie says above, the ability to run it lots of ways makes it a winner. If starting from scratch though i would be very tempted by a karate monkey as that has even more versatility (and weight), but if you wanted to race 3 peaks you may not be allowed on a monkey.Sizing wise, i got a 52 and have a 29/30″ inside leg. They come up longer than some i think. I was concerned this may be a little small but it is spot on with a 100mm stem and midge bars. THe only thing to watch out for is the short headtube – i have got a lot of spacers to get the bars where i wanted. Not much of a problem, but doesnt look as good as it might 🙂
DaRC_LFull MemberHad mine just over a decade and it’s been perfect for winter commuting – started off with gears but after salt destroying derailleurs a couple of winters ago have gone to singlespeed. It’s excellent.
Done some off road on it and some sportives on it – it’s even made it up Alpe d’Huez.
I’ve got a 52cm and a 31″ inside leg and it’s fitted fine.
karnaliFree Membersizing wise i’m 5’8 and alittle bit i’m think 50 or 52 using tt length
ta
antigeeFull Membermatthewlhome Sizing wise, i got a 52 and have a 29/30″ inside leg
thanks that helpful
matthewlhomeFree Membershould have added that i am 5’10” so long body and short legs 🙂
birdageFull MemberI’ve got a CC and tricross.
As others have said the CC is fantastic, I have mine ss and it is without doubht one of the most comfortable bikes I’ve ever rode. Eats up the miles and keeps track with bikes much lighter and more road specific. Obviously the swiss army virtues of the bikes is a big plus though it looks so good ss I don’t know if would want to put gears (or weight) on. I don’t think it could quite do the kind of single track the tricross is capable of and I know which one I prefer to lift over fences, gates etc. I know some people who have done some long and confortable tours on the tricross but I suspect the cross check would be better. On the surface both seem quite similar but I ride them both regularly and get different kicks from them. Doesn’t really help does it? Probably explains why I’m giving a Swift a go!firestarterFree MemberGreat bike many uses 😉
Fixed commuter
Ss cx
Geared monstercross
STATOFree Membermy only hesitation at present is trying to find one 2nd hand and also looking to see whne and how much the mk2 kaffenback is going ot be as it look slike having bigger clearance than the original one
From what ive seen it looks like they just grafted an inbred seat-stay and dropout onto the existing Kaff, so at first glance it looks like there is loads of room but the chainstay clearence still looks tight.
Pics from Placid-casual…
kaffenback mark 2 by placid casual, on FlickrcharliedontsurfFull Member‘avin some singletrack with olive the dog… crashy on another surly cross check follows.
On the way to belgium ssec
CHECK MY ONIONS OUTrichpipsFree MemberI had a cross check, no way I’d want to cart one up the 3 peaks.
penttikFree MemberI’m still collecting parts to build my single speed/fixed cross check. Been commuting on my steamroller fixed, so I’ve got a selection of fixed cogs for road use, but am trying to decide what size free wheel to buy for single track use.
What gearing (inches) do you guys run on your single speed cross check? Please specify on-road/off-road and fixed or free wheel.
Thanks.
cynic-alFree MemberKaffenback has to be way better value – no discs on the Cross-check, no lighter.
I can just about get 42mm tyres in my Pompetamine if that’s a guide.
STATOFree MemberWhat gearing (inches) do you guys run on your single speed cross check? Please specify on-road/off-road and fixed or free wheel.
I run a W/I DOS-ENO, so my two freewheel ratios are usually…
40/16 on-road
38/18 off-roadThese both have almost the same effective chainstay length so i can change gear without having to unbolt the wheel, just requires a bit of brute force :0)
However, just recently changed to a lower offroad ratio as ive been doing some weekly CX races and the organiser likes putting in some harsh climbs. So right now im running…
38/16 on-road
34/18 off-roadThankfully the dropouts on the CrossCheck are long enough to cope with the difference, just requires unbolting the wheel, nudge the chain across, pull wheel back in drops and tighten back up.
oldgitFree MemberMark TBF cx tyres and mudguards are an odd combo. The CDF has Crud bosses for off road use. And the Crosscheck is V/Canti as oppossed to the CDF being disc only.
Just built a CDF, I’d been toying with the idea of one of these CX heavweights for a fair while, but the one criteria was that it must be geared to get up long non technical snowy/sandy/chalky/grassy climbs. And I wanted it to be proper off road capable. So for mine I cut the clamp on some Deore hydros to fit drop bars. Not that I’ve used cable discs, but it does mean I can decend like the clappers with just one finger coveing the brake. I went MTB gearing on the back to be on the safe side, road up front.
It was a choice of Cotic X, that was too close to my ‘proper’ crosser. Road Rat, not recommended for off road. Crosscheck, I wanted discs, I know how good cantis are! Then a deal came up on the CDF.
BTW I have had 42s in mine in the shop.
However I had decided that I’d probably sell it when it was built to fund another training bike.oldgitFree MemberMy thing. Highly capable. Though I’d go for a crosscheck if your riding leant more towards touring and not something to take the place of an MTB.
oldgitFree MemberThis shows the Midge bars. These were a revalation. The width is essential off road and the shallow drop gives a great all day road position. I might even put them on my crosser
oldgitFree MemberThe extra extension on Woodchippers would I think be useful. But the Short Midges worked very well with bar end shifters. Just needed to shift with my little finger or heel of my hand.
Bar end shifters -I couldn’t beleive how good they are. I thought being what is really retrograde? item that they wouldn’t cut it. But in friction they go through the gears like a hot knife through butter.
Putting them on my winter hack.spokeblokeFree MemberMine has bullhorns and a basket on the front and does everything.
Scares the legshavers on a Sunday morning too.Would buy another tomorrow. Only criticism – the stickers are cack.
skyhigh_71Full MemberHi Nedrapier – PM’ed you today reference few questions on your Peregrine build – please see your hotmail.
Thanks
skyhigh
RikFree MemberFirestarter – did you ever get my questions about your 1.8 tyres??
charliedontsurfFull MemberRatio. 42:20 for everything from road touring to xc racing.
The topic ‘tell me about surly cross checks and anything else similar thats as veristile..’ is closed to new replies.
