Nice cars. Essentially based on the freelander which in my opinion is fairly good in terms of reliability. I had a freelander, and also a evoque for a short while – so comments are based on both.
I found the 2.2 diesel engine to be plenty powerful when under boost, but gutless at low revs and no boost.
Manual clutch can be quite grabby at the bite point due to the dual mass flywheel.
Automatic is nice enough and I liked the flappy paddles on occasion, but on the whole it seemed to not get too confused most of the time.
The freelander had an issue with the rear diff pinion bearing, which could also be applied to evoque. The bearing was under-specced, leading to premature wear. Its not too difficult a job to change out the rear diff though.
I had a turbo issue with my freelander, and also a throttle body issue. Both fairly easily fixed.
Light coloured leather can get jeans marks quite easily apparently.
We are considering an evoque as a replacement for one of our cars.
