Nowhere in the mag does it say anything about minimum spec to accomodate a large route (such as the one I mentioned). Hence my question.
Fair dos.
The eTrex H will store 500 waypoints in up to 20 routes, which should be enough for the Trans-cambrian, depending on the level of detail you want.
The TC is 100 miles? and so 5 waypoints per mile should be enough?
I wouldn't bother with a mapping unit, because the off-road maps are poor.
So an eTrex H would do the job and would be my weapon of choice.
Frog cameras have them in for £60, but you would need a cable and mount – probably another £25 ish
LINKY
Oh and if you want to use it with an OS Map DONT get an Edge because it wont give you and OS grid reference.
