Not that simple on dual positions. The air shaft is different to solo airs and rockshox don’t make an air shaft for shorter than 150mm max travel as far as I know. It’s not on the tech manual or the parts catalogue.
Just shortening it might not work as shortening the air shaft just essentially pulls the lowers up the stanchion, this might cause problems with the piston as there’s obviously more in that leg than just air on the solo position model. Drop tf tuned a mail if I were you.
Edit: Given that on solo air each wheel size up drops 10mm on the same damper, in theory fitting the 150 27.5mm dpa full assembly might do the job but no idea if it would work, rockshox don’t list it as compatible like they do with the single position parts. Rs part no is 11.4018.010.114
