Viewing 5 posts - 1 through 5 (of 5 total)
  • Tech advice GXP BBC. COTIC Soda.
  • chilled76
    Afternoon all,
    Got a new GXP threaded BB. It’s come with 2 spacers… is it one each side? There’s no diagram to show where to place them?
    Going on a Cotic Soda (68mm bb).
    Thanks in advance
    vincienup
    If you’re asking this then you should read the SRAM tech stuff (links below – BB install is p9). The principle of preloading is different to Shimano.
    But yes, 68mm BB = 1×2.5 spacer each side.
    https://www.sram.com/truvativ/technologies/gxp..-external-bottom-bracket
    https://www.sram.com/sites/default/files/techdocs/2014_xx1_service_manual_0.pdf
    letmetalktomark
    Are you sure it’s 68mm on a Soda?
    Every Cotic I’ve had had a 73mm BB. That said I never got as fancy as Ti 😆
    DiscJockey
    The latest Soda has a 73mm shell – I presume older ones are 68mm.
    As said, you normally put a spacer on each side with 68mm shells, but bear in mind that you can put both on one side, for example if you need to adjust chainline.
    chilled76
    Yeh it’s a mk1 and it’s definitely 68mm. Thanks guys, 1 spacer each side is what I kind of figured as they are 2.5mm each.
The topic ‘Tech advice GXP BBC. COTIC Soda.’ is closed to new replies.
