i've been a believer in eggbeaters for some ( 4 or 5 ) years. easy in, easy out, and have used candys and mallets extensively.
found candys give enough support, and with the right boots ( i use shimano mt90 ), you get enough purchase on them to unclip or pedal unclipped until you get a second to clip in.
i'm going over to times. just as easy in and out, and i went to service a set the gf has had for 4-5 years a while back. i took the pedal off the spindle, and put it straight back on again – nothing to do.
i'm not saying too much more because i intend to put in a warranty claim on my most recent set of candy sl which failed catastrophically on a ride, which would not have been prevented by servicing.
the later ones look like a better design, with two bearings rather than just one with a bushing, but this still would not prevent the failure mode i experienced with these pedals.
shame. i have liked them, but i've had enough. i honestly have no axe to grind here. i've persevered with these for some period, as they do work nicely, but i can't put up with something that fails like these did.
never found cleat wear a big issue, which i know some people have experienced, and bought a stock of bearings to service 'em with, so cheap and easy to work on. unfortunately the pedals themselves only seemed to last as long as the cleats. either there was some significant failure or the wear to the bars was enough that they just needed replacing complete.
look at the time rock and freeride pedals as alternatives. only go for bigger cages if you feel like you need to support your foot to stop it from rolling around, IMO.
HTH.
