hi folks im basically at the moment only ever using middle ring on a 3×9 setup with 34t rear sprocket….
i run middle ring even on the steepest of peaks of climbs (willy waving waheey) and havent used granny for as long as i remember…i also only ever use the outer ring for descending on road (linking routes together)…
so my question is, if i go 2×10 on the new xt stuff, what else will i need? is it easy enough to do on a five frame? or will there be issues with clearance of swingarm etc?
also the 2×10 is offered in 38x26t or 40x28t and id run the 36t rear sprocket….which would best for peaks use out of the two options?
im guessing this gearing will be alot more suited to me, as its using higher gears which im currently doing….
any help and suggestions really appreciated, im saving up already for it 😆
would i have to get the whole shebang, new chain, front mech, shifters, rear mech etc?
or could i until affording it properly, run it 2×9 and just buy the chainset and use it first off?
