past 6 months, ive started getting these really bone (rubbish) punctures.
under heavy braking, the front front tube gets a nick or cut in it at the stem, or the stem comes clean off.
ive tried filing the hole so its a rounded surface, but it still happens.
obviously, having the stem come off the tube means every time this happens its a new tube :'(
(im a tube mender, not a tube binner like some of you lot ;))
someone mentioned to me this past weekend, that it is caused by the tube being stuck to the tyre. over time, the tyre becomes a bit sticky inside (reusing tubes wont help i guess), so the tube sticks to the tyre, the tyre moves under braking a little (im using conti folding tyres on 717 rims, so they are VERY easy to get on and off, not tight at all) and this causes the tube to get moved with the tyre.
subsequently, he reckons that talcing the tyre inside, will prevent it from moving the tube (as much?).
does anyone else do this?
a quick google indicates some do, most dont, wondered on what you locals thought.
