Anyone using a sx trail 2008 style or older with single ring up front? what chainguide did you use? I'm having trouble with e 13 lg 1. Mount to ISCG tabs and i have to space it out with millions of washers and it clashes with chainstay, tried both normal and wide angle plates. BB adapter still clashes which means cutting away alot of the lg 1 plus buying a new chainset without granny ring tabs on. Anyone used a chainguide which just fits straight on?
grinding/cutting off granny tabs is perfectly normal for fitting a chain device to many bikes.
sorry can't really help you with any of the rest of your issues.
Yeah i have hone cranks, i might look at gamut then, i don;t really want to file of the granny tabs, i was considering it but cant use them if i want to go double again!
Did you shave off the bottom plastic bit you mean? i could do that but then i have to add serious amounts of washers for it to fit over the chainring. Maybe the hones are causing the problem to.
I run a blackspire chainguide and hones on my 07 sx trail with no modifications required. Can't remember the specific model and not at home but its a c something – sorry can't be more help!
Steve
The SX/Enduro/Demo are notoriously incompatible with e13 SRS and LG1 guides and almost always interfere with the chainstay. The newer version of these (the SRS+ and LG1+) should have addressed the issue – is it a new version you're using?
If not then typically what you need to solve the problem is an extra wide backplate comme ca:
The other thing you can try is the ISCG adapter plate that should have come with the guide. Should look something like this:
You can turn it around to space the guide further away from the chainstay. Obviously you mount the adapter behind the BB cup and thus don't use the ISCG tabs.
I;ve tried the LG 1 old style and a bb adapter with also a new wide plate of crc. It just pushes it out to far and hits not just the granny ring tabs but pretty close the ring itself. Someone did say that you get thinner bb cups and also wider ones which push out the chainset, maybe the hones and lg 1 combination are the problem.
Can also recommend the Gamut. After **** around with an e13 SRS I also gave up and stuck a Gamut on. This was an 05 Enduro and it fit perfectly first time.
