I am clearly not the chosen one because there is know way in the world my hope pro 2 freehub is going to come off. The original problem was that when I tightened the qr the compression caused the freehub to stick. When the qr was not engaged the freehub would spin smoothly but turn the axle too. Having soaked it all in penetrating spray the freehub will move independently of the axle again but there is no way it’ll come off to allow me to replace the bearings.
I know this topic has been covered before but I’ve tried all of the methods mentioned but had no luck. It was bad enough getting the end caps off which were totally seized on but the freehub is just not budging. I have ran out of ideas, Im sure that the hope service video with the guy simply popping the freehub off a new hub has been made simply to torment me! 🙂
