Hi.
As above. I've got a 9mm DT Swiss through axle (works with standard QR drop out forks) that I would like to swap for a rear 135 x 10mm through axle of the same make/design.
I've got one of these on my commuter bike, (Kenesis XC Pro2) and even on this, just on the road, you can feel the difference in rigidity of the fork and the fork/wheel interface when cranking it over in turns. This second axle is un-needed now as on the other bike I've gone over to a 15mm axle fork but would like to stiffen up the rear end (oor err misses) with the use of one of these and the appropriate Hope 10mm hub adapter/axle.
Michael
