May also be compression. Or spring rate. Many, many variables. Compression makes a huge difference to the ‘kick’ you get from jumps.
True, but IME they all do it by interacting with the rebound.
Too much LSC and the suspension doesn’t compress, but that’s not a bad thing (hardtails jump just fine).
Too little LSC and the suspension uses too much travel, then when it’s released at the lip your relying on the rebound to not kick you forwards.
Too low a spring rate will make the bike ride horribly over jumps, but mostly just by offering no support so you just don’t get the same height/distance/speed.
Too high a spring rate for the damping and it overwhelms the rebound after take off. But that’s not the springs fault per se, it’s mismatched spring/damping.
Rebound sounds like a possibility but I didn’t know there was the possibility of low speed and high speed.
If it’s the original Fox DHX then it’s not possible to adjust high and low speed rebound separately. BUT if it has a bottom out adjuster (DHX-5) then you can manipulate it slightly by going down in spring rate and upping the bottom out. This means the shock will still take the same force to bottom out but will sag a bit more too. The knock on effect on jumps is you now need less damping to deal with the lower spring rate in the portion of the shock stroke that’s used on takeoff (the middle third or so).
