I’m building up a new bike for my daughter and I’ve a pair of SIDs to put on it.
She’s only eight, so I’ve changed the travel from 100mm down to 70mm.
When I put the oil in the damper, I decided to put less oil in than recommended, to see how it performs.
With the low weight oil in the fork, the compression seems nice and active. The lock out doesn’t work, but I’m not bothered about that.
I also seem to be able to setup the rebound exactly as I would want.
The question is, for all you suspension gurus, am I likely to cause any damage to the fork, running it with less oil.
