cullen-bay – Member
they are surprisingly fast!…
Shame that can’t be said for the owner 🙂
The shift from a 29er to fat wheels was a revelation. Even greater than going from a 26″ wheel to 29er.
I can see my fatbike becoming my only mtb which means I will be offloading my 26″ and 29er bikes and components.
I think if your emphasis is on trail park riding you won’t be exploiting the full capability of a fatbike and possibly handicapping yourself, but as a point to point or adventure bike it’s pretty hard to beat, and amazingly good on rocky bits.
The only thing I would change is the weight. It is not a problem in general riding – simply don’t notice it because the wheels seem to have less drag offroad – but when it has to lifted over a fence, aaargh!
I think my Pugsley is about 40lbs with an Alfine hub.
The offset on the Pugsley has the advantage that you can use readily available mtb hubs. Wider hubs tend to more expensive and heavier. The problems with the offset can be countered by drilling your rim with offset holes, and/or doing a crossover lace up, which will give you a very strong wheel. I built an offset wheel with an Alfine with a normal central hole spoking, but I felt that it would be too fragile, so I dismantled it.
