Switch fronts are easy. The thru axle adapters will pop off in your fingers (20mm ones do, so I assume 15mm will). The QR ones might need a little leverage with something due to the o-rings. Though if you lose one of the 2 o-rings per adapter they’ll still stay put but you can pull them out with your fingers
“upgrade to 10mm rear QR too, its about a tenner for the axle and £7 for the qr “
The only thing against the superstar 10mm QR thru-axle would be the steel axles make them not the lightest. The american classic 10mm thru axles appear to be the same apart from being lighter due to iirc aluminium axles, £17
If you’re a worrier or just don’t like external cams then DT RWS (QRish) 10mm thru-axles are lighter again and aren’t thaaat much more, £30/35
Off the top of my head I don’t konw of an internal cam’d thru-axle (ie like shimano/mavic)
