Viewing 5 posts - 1 through 5 (of 5 total)
  • Superstar zinger tensioner problem
  • maurizio
    Hello stw massive!
    Recently bought one of the above tensionerers and I’m having a problem: the bolt used to screw into the mech hanger has a metal bolt sheath over the top that means even when screwed in tight to the frame the tensioner slides about 2mm from side to side. This reversed metal sheath/bolt thing actually protrudes past the surface of the tensioner…
    Any thoughts? I can take a picture if that helps! Any other zinger owners?
    Thanks in advance fellow trail conquerers 😀
    thepodge
    I worried about this too but fitted it anyway.
    I’d forgotten about it till seeing this thread so I guess it doesn’t matter
    maurizio
    Interesting.. Is it still wibble-wobbling?
    thepodge
    Nope and I’m using it on a full suspension frame so it’s probably getting a harder workout than usual
    I have set it up with loads of tension and a really short chain which probably helps
    maurizio
    Good to hear! Anyone else? Before i pop it on and lose the return..
The topic ‘Superstar zinger tensioner problem’ is closed to new replies.
