Firstly, on the evidence of your first shot, I'd get your sensor cleaned 😉
As for filters, if you are serious, the only way is Lee. Yes they are pricey, but they are much more neutral than any other make I've used. It's a slot-in system like the Cokins, so you only need to buy one set of filters, and just get a different adapter ring to make the holder fit on different lenses.
If you're just after slowing things down for movement, then maybe some Hoya screw-in NDs would do you, but anything involving a graduated filter to expose for the sky and the foreground, you really need a slot-in system so you can adjust where the graduation falls…
