I wonder if the STW masses can help with this one please;
200 yr old farmhouse in rural area, which was completely renovated/rebuilt last year, with modern insulation, wiring, heating, lighting, etc, etc.
Outside walls consist of 3ft thick stone walls, which appear to be a stone inner/outer wall and a rubble filled void in centre. Inner wall is 50mm kingspan, lined with a vapour barrier blanket. Some inner walls are stud walling. Ceilings are std floorboard/joist/plasterboard affair. There are a couple of small voids near window bays.
We’ve been in the house 6 months. 3 nights ago we heard scratching behind one wall….rats. Tonight we’ve heard more scratching/scrabbling behind same wall, also near window void and also in ceiling near void. It sounds like there are three or four rats.
Looking on the outside wall, I’ve found a old pipe exit hole approx 2″ diameter. Looking in the hole with a torch I can see through the wall void and to the back of the vapour blanket! No way of telling for sure, but it seems very likely this is where the rats have gained entry. Bizarrely I’ve never noticed this hole before and I’m a bit pi&&ed off the builder left the hole unsealed.
I’ve now borrowed a lobster pot type rat cage trap from the farm next door, baited it and have blocked the exit hole with the trap (the only way they can get out the hole is via the trap). 12 hrs later no rat caught yet.
Anyway…presuming there isn’t another entrance hole somewhere else (which there may be, despite me looking) how do I get rid of these rats??
They are definitely multiple rats in the wall and ceiling so I can’t use poison and there is no way of setting traps in the wall voids, apart from cutting open the wall and creating an access panel, then laying traps in the voids. But before I go ripping apart the walls of a newly rebuilt house, which i really don’t want to do,, anyone any experience of this kind of problem?? Any advice??
We have a cat, which is currently going ballistic and jumping up at the wall where the noises are. So hopefully it will catch any that make it actually into the house itself.
Maybe it’s a case of just waiting until the trap outside the entrance hole catches them?
